12-14-2021 05:56 PM - edited 01-04-2022 04:57 AM
Hi all,
The other day I updated my phone from Android 9 to Android 10 and since then I have been unable to send pictures over MMS. This happened when I first got my phone and I found the solution on here which was to set the proper APN. But this time it is not working. Has anyone else experienced this or have any other ideas? My phone has been doing some other strange things as well. Here are more details.
Phone: Kyocera E6910
OS: Android 10 version 6.052VZ (recently updated from Android 9 version 4.801VZ
Symptoms:
- Can't send picture MMS messages
- Can't send pictures over facebook messenger
- Sending pictures over email works fine
- Music App (poweramp) can no longer find music even though I can see it is still there in File Manager
- I can no longer search for contacts in the phone app. They are still there, I can manually scroll to them, but search turns up nothing.
Any help would be greatly appreciated. Everything was fine before the update
a month ago
reset nwework won´t help since there is a bug in the the Verizon software/firmware.
The best is to ask Verizon if there is a coming update about the MMS problem
12-17-2021 07:19 PM
you can try reseat the SIM card and Make sure your phone is off before removing your SIM card,
1. power off your device
2. take out the SIM card,
3. waiting a 1 minute,
4. put it back and power on,
5. toggling airplane mode off/on,
or visit Here link,
APN Settings On Android device
click Here link,
Ensure you have the correct APN settings by visit Here link,
and try manually selecting network "3G ONLY" or WCDMA only,
for android visit Here link ,
Turn your data on to send a Picture Messaging in world-wide,
if your data is off and your home internet Wi-Fi is on is not going through the Picture or a video messaging,
you have to do this to going through you will need to turn your data on to send a Picture or a video messaging in world-wide,
make sure your Data is on.
and do Rebooting your phone ,This is quick and simple,to refreshing your network,
*what is meant by rebooting the device turn off and turn it back on.
12-17-2021 07:16 PM - edited 12-17-2021 07:17 PM
@softech wrote:@Fgignac yes, unfortunately Factory Reset won't downgrade the OS. You will have to download the Android 9 image and flash the image.. some technical work involved.
WOW!. I am not recommending playing with manual downgrade/upgrade OS with 'images' (custom ROMs or official images) as you can easily brick your phone (unless you KNOW what you are doing). Do it at your own risk, read how it is done and if comfortable, take a deep breath and plunge...
12-17-2021 07:07 PM - edited 12-17-2021 07:08 PM
12-17-2021 07:06 PM
@Fgignac : Maybe post screenshots of the APN settings you're using and we might spot something or suggest some alternatives.
12-17-2021 07:01 PM - edited 12-17-2021 07:05 PM
Thanks so much for all your replies.
I have has this phone for over a year and everything was working fine until I "upgraded" from android 9 to android 10.
I tried everything that was recommended above with no success. Finally I did a factory reset, hoping the phone would go back to Android 9. After the Reset I am still on Android 10, but most of the problems have resolved.
The only remaining issue is that I can still not send pictures over MMS. I have made sure the APN setting are correct, as recommended above. The I reset it to default. Still no good. I have tried 3 different messaging apps (Stock, Textra, and Signal)
Any other recommendations?
12-14-2021 11:44 PM
"APN Type = default,mms"
(restart)
"default" should work, it usually does. But some Android devices are quirky and require explicit configuration directives.
If it still won't work then try installing different SMS/MMS app instead of using the built-in software. Signal SMS works for me, but there are many good free options out there.
12-14-2021 09:05 PM
Have you checked if you allow permission for the apps to use your camera or access your photos?
12-14-2021 08:24 PM
Try updating all apps to the most recent/available version.
12-14-2021 08:00 PM
@Fgignac wrote:Hi all,
Symptoms:
@Fgignac - well that sounds annoying to happen after an update 🙄.
Before jumping to a Factory Reset just yet, why not try these things first:
C - uninstall your Messages and Contacts app.
Then reinstall the apps.
12-14-2021 06:07 PM
if not fix it try to backup and factory reset, How to Factory Reset.
12-14-2021 06:03 PM
or visit Here link,
click Here link,
12-14-2021 06:02 PM
@Fgignac you have so many issues, different type. I wonder if you will factory reset your phone and start new..
