Prices
Stevenclt2b
A friend want a plan with 38 Gigs of data and Canada wide.  How much should it cost him?  Does public have a plan?
Luddite
@Stevenclt2b Renewing the $50 plan as needed 38 gb/30 days will cost $237.50/30 days.
Reynolds10
Hi there!
For ease, here is a link to all Public Mobile's plans:
https://www.publicmobile.ca/en/on/plans#plans-start
And for any add-ons you would like to purchase, just simply click on the drop down where it says.
Cheers!
katherineb379
At PM there highest data plan is 8gb for $50 a month. There are many back to school deals going on right now your friend should try another provider such as Koodo, Telus, Bell, etc
gblackma
Public doesn't have a plan like that @Stevenclt2b  38 gigs? Is thst a typo? Thanks.  You should look at Telus.. There's a 20gig plan that gets throttled to 512 3mbts if you run out of data.Stay safe
gpixel
@Stevenclt2b
I think your best option would to switch to either Telus or Koodo. Koodo has a promo for $60/13gb
