09-04-2022 08:55 AM
Does Public offer reward points for pre authorized payment on my Credit Card
04-09-2024 09:07 AM
yes, old reward program is better
04-09-2024 09:06 AM
hello,
for pre-authorization, Public Mobil will only going to charge the set amount after deducting $2 , I hope this is helpful
09-04-2022 09:10 AM - edited 09-04-2022 09:11 AM
yes, in general, DO NOT migrate to the new systems.
Another major disadvantage is the nee Anniversary rewards compare with the Loyalty rewards on the old
Anniversary rewars only gives you 10 Points (= $10) every year, while the old Loyalty rewards give you a total of $12 on the 2nd years, $24 on 3rd and as many as $60 on the 5th years and thereafter
But, if you joined after Jan 25, you have no choice but to join the new system
09-04-2022 09:08 AM
09-04-2022 09:07 AM
I feel the old rewards program is still better for pre-authorized payments
09-04-2022 09:05 AM
Thanks so much for the info....I prefer the old rewards program
09-04-2022 09:01 AM
09-04-2022 09:01 AM - edited 09-04-2022 09:02 AM
09-04-2022 09:00 AM
Anyone who activated after January 25, 2022 is automatically on the Public Points rewards system and is not eligible for the $2 autopay reward.
OR, if someone switched from old to new rewards, then autopay is not available either @OS-10 .
09-04-2022 09:00 AM
@OS-10 no, the new rewards system does not give you any reward for enabling Pre-Authorized payments. You get 5% back in point for all purchases and spending instead
09-04-2022 08:58 AM
The old rewards system gives you rewards for setting up pre-authorized payment .
Does the new new reward program gives you points for that ???
