04-09-2022 03:46 PM
04-09-2022 10:25 PM
haha @Idaar1958 do it yourself, it's self-serve, no frills of cell service here.
04-09-2022 04:42 PM - edited 04-09-2022 04:43 PM
@Idaar1958 wrote:Could you please remove my pre-authorized payment from my account?
Thanks
@Idaar1958 if you are no longer a customer with Public Mobile (ported your number out of here, or it has been over 90 days in suspended status, then does that mean you are still getting charged?
If so, contact Public Mobile Representatives (CSA) by submitting a message(ticket) to them here:
Private Message to Public Mobile Customer Support Agents (CSA)
If the above is not your situation, other posters have you covered.
edit, typo
04-09-2022 04:41 PM
To be extra safe you can just remove the card altogether and do payment manually when you want if and when you renew.
04-09-2022 04:32 PM - edited 04-09-2022 04:32 PM
Thanks
Go into your self serve account. Click payment tab at the top. Click Manage My Card at the bottom to change/edit CC details. Click Manage Autopay to, well, manage autopay.
04-09-2022 03:55 PM
Or if you remember your 4 digit pin then you can dial 611 and turn off autopay. It doesn't remove the card but it shouldn't charge.
If you might have already ported out then just keep watch on your credit card for a possible charge when you would have renewed. If nothing happens then you're done.
04-09-2022 03:54 PM
04-09-2022 03:47 PM - edited 04-09-2022 03:48 PM
Hi @Idaar1958 you can do it yourself. login to My Account, Payment Tab, Autopay and you can then disable yourself there
