06-18-2021 04:28 PM - edited 01-06-2022 02:34 AM
Courtesy to @annie8 ,
- looks like it's a nationwide issue with account creation but should be solved within 24 hours.
06-20-2021 08:39 PM
Don’t forget to use a referral code from any PM members for a $10 discount on your 2nd month bill. 😉
06-20-2021 07:52 PM
Good luck..
Just a reminder if you are porting your number into PM, make sure you know that you need to reply and SMS from your old provider to confirm you are leaving.
Enjoy PM.. enjoy the saving.
06-20-2021 07:41 PM
Cashe should be cleared with each restart but the issue remained, seems to be limited to Firefox on windows7 as my other computer on windows10 works. I'll continue on there.
Thank you
06-20-2021 07:34 PM
it might be cache issue. The activation is up
did you try a different bowser? Chrome/Edge/Firefox.
did you clear the cache and try again?
did you try to use Incognito mode?
did you try on another computer?
06-20-2021 07:31 PM
Yup we tried all day yesterday and this morning but the activate page never loads. just spinning ball of doom
06-20-2021 07:30 PM
@Drewnar you try to activate now? I can access the page without issue
can you access it at all? or you got hung in a particular page in the process?
06-20-2021 07:28 PM
48 hours later the Activation page is still offline
