Posting for a friend
pharris
A friend is having problems with her account. Hoping someone here can help. As follows:
Hi there,
I wanted to sign in and had lots of issues.  Finally I was able to sign into my account (after having to change my password twice) but not to the Community.  I am trying to register in to the Community section but it hasnt been accepting my passwords even if I change them on the site.  Somehow I got a ticket sent but to respond to it I have to be able to log into the Community site!  Which I seem unable to do. Which is my reason for putting a ticket in.   I don’t know how to reach a moderator.  The bot is useless. I was wondering if you could send a note in about my account and the issues I am having.  If I could have a direct link to a moderator that would help. Her name:
Thanks,
- Paul
Edit by popping:  Remove the photo with account info as anyone can access your post.
8 REPLIES 8
@pharris
That's your best bet to contact them if the matter is account-related.
They may have to verify the account so be sure to have the account verification items close by so the Moderators can ensure they're dealing with an authorized request.
RosieR
@pharris
EDITED as a solution had already been accepted
Aloha
RosieR
popping
@dabr wrote:
@HALIMACS wrote:
@pharris
PLEASE remove the personal information by clicking the 3 dots on post and EDIT it.
This is a PUBLIC FORUM.
(EDIT:   Thanks for quick action, @popping !!! )
Maybe @popping  can also remove the name in OP's post too, I guess it got missed!
Thanks and done.
pharris
Thanks. That was a fast response. I now realize I shouldn't have published her acct info. I'll take your advice and contact a moderator.
- Paul
@HALIMACS wrote:
@pharris
popping
Hi there,
Her name: xxxxxxx xxxxxx
Her acct:
Thanks,
- Paul
You can create a ticket on your friend behalf OR ask your friend to send a private message to the moderator team directly after login to the community.
@CS_Agent
I also tag the moderator team to contact you.
HALIMACS
Here's how you reach a Moderator, @pharris .    If you're having problems with Option 1, use Option 2 to directly private message them.
To contact a moderator, there are 2 methods:
  1. Use the ticketing system for a faster response time. Click here and type moderator, then select contact us, then select you need a human now.  Follow the prompts to submit a ticket,  or,
  2. Send a private message to the moderator by clicking here  You’ll need to be logged into your Community account for the link to work.
HALIMACS
@pharris
