3 weeks ago
My postal code only has changed and my on line profile won't accept the change? Who can I contact?
3 weeks ago
@RacheyD , you should be able to change the postal code using the app, make sure to delete app cache and enable location permission first. When entering data in the address field, enter the full address including street number. If things are working you will see the location server show a pop up of the confirmed address for selection.
3 weeks ago
@RacheyD, If you continue to have problems trying to save the changes through the Public Mobile app or web browser you can open a ticket through the Chatbot: https://widget.telus.tiia.ai/publicmobile/publicmobile.html
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
3 weeks ago - last edited 3 weeks ago
You can change it on the PM app under Account tab>Manage Profile>Edit Personal Information and edit your address and postal code.
Remember that the postal code must match if you are on AutoPay/Subscribe when you update your Card Information or the AutoPay won’t work.
