Porting
byoungchul
I attempted to port my Fido number to Public Mobile.
While my Fido SIM was temporarily removed, the porting authorization message was sent.
Unfortunately, the response time expired before I could reply.
I have since reinserted the Fido SIM and sent “YES,” but it seems the porting process did not complete.
Could you please assist me in re-authorizing the port so that the process can be completed?
Thank you very much for your help.
1 REPLY 1
@byoungchul
There is a number to call to talk to live support,  they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
