03-15-2024 08:11 PM
Hey all,
so recently had a dual sim set up with a Fido physical sim with my number and a pm random number to test out via esim. I am very happy with reception so I transferred number in app. I got the text and confirmed transfer but on the last page of the transfer I hit back by accident and missed the final screen.
I can make calls but can’t receive. Do I need a new eSIM now that I’m using a different number than previous for pm or will it take a bit to transfer?
Joining Public
03-15-2024 10:49 PM
Yes, need time for transfer, I only take 10min but I know some people can take about half day. BTW, are you sure you use PM to make call? I mean the same number?
03-15-2024 08:30 PM - edited 03-15-2024 08:30 PM
Glad it's working. Sorry you had to purchase another eSIM. However, if you wouldn't mind, it was @hTideGnow who gave you the suggestion of calling the porting line and provided you the number. Would you mind changing the solution to their name? Much appreciated. Enjoy your weekend @Enfe
03-15-2024 08:27 PM
Thanks all for quick responses. I did call pm port number and they answered quickly and told me I had to purchase a new eSIM. I did and it’s now working. Thanks again!
03-15-2024 08:18 PM
Hello @Enfe
If you said yes, let me ask you this. If you have your Fido SIM card in your phone now, do you have reception still where you can make calls? If so, then the port did not work. If you can't make calls, then you may need to go into your phone settings and choose the PM eSIM as your primary number then reboot the phone. Give that a try first. Let us know if that works. If you don't know how, let me know what kind of phone you use.
03-15-2024 08:12 PM
hi @Enfe
what you experiencing about inbound not working but outbound works is normal when port is not completed.
PM porting support team can help. I have sent you the porting support team number. Please check your Community inbox (envelope on top right), check for the number and call
