Porting my number
Samianauman
If I change my number in a billing cycle I mean I already change my number once during 90 days plan if I still have another line with other carrier can I port number from other carrier now or since I changed my number I can't change until after renewal date
** I am not a Mod, please do not include any private info in a private message to me.**
7 REPLIES 7
leandrofontp
I think you can change number every 30 days, but to change number you have to cancel it with the other carrier first
lol I can't port now I have enough money for next few months if I ported now I will lose all that money 💰 sitting in my account I gave that line to my daughter to use it until it's has money then o will port before that line get expired 😉
Watoko
When I activated with PM, I created a new account with a new number first, and then ported my number from Koodo. After about a week or so, I was curious if the Toronto numbers changed drastically (I didn't like the selection of the 3 digits after the area code at the time), so I went to the Change my Number page, and it allowed me to choose from the list. I still didn't like the selection so I didn't proceed with the change but I was thinking if porting counted as a number change, then in my scenario, I shouldn't have been able to view the available numbers? But this is assuming that the error message occurs after I confirm the number change.
If you wanted to port over your number, could you not try it out yourself and see if it works? Worst case scenario I see is that it just won't let you proceed any further after confirming eligibility of porting.
Porting have a same 30 days rule or can be done without 30 days restriction as long other line is active ?
NDesai
They allow number change after 30 days. It is nothing to do with your billing cycle but of course, your status should be active.
Watoko
My understanding is that the once a month phone number change is only if you wanted to choose a new number from a pool of available numbers. Porting your number in should override that, as you don't need to choose from that pool; the number already exists. So would that actually count as a new number change?
will13am
You are allowed one number change every 30 days.
