Porting issue
01-14-2024
10:29 PM
01-15-2024
09:19 AM
computergeek541
just activated new account. I can call out however incoming callls go straight to voicemail. I'm assuming there is issue porting my cell number from Rogers. is there a way to corrrect this?
Joining Public
01-14-2024 10:48 PM
I would check to see if your Rogers sim card still work. Also a reboot of the phone should fix it, if the port was done correctly. (airplane mode should work, but better to reboot.)
01-14-2024 10:34 PM
Can you check if your Roger SIM still work?
If so the port was not done correctly. I will send you another message with the number to call to fix.
