Porting in
HongHong
Good morning there,
My number port is completed. I can make outgoing calls, but I cannot receive incoming calls.
Please refresh or reset the voice routing on my line.
BW99
Hi I have the same issue, is it fixed now ?
monica11111
I have the same problems
hi @HongHong
Did you get a text from the old carrier, did you reply Yes within 90 mins?
and can you receive inbound phone calls, especially from Non-Telus/Koodo/PM phone?  If you cannot the port was not done
It could be an incomplete port.  PM porting support team can help.  I have sent you the porting support team number.  Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway),  you can submit  ticket by direct message:
