Porting in from koodo postpaid
yoshanaku
Trying to port in my koodo prepaid number to PM, not working online. Store called service number and got nowhere
10 REPLIES 10
CS_Agent
Customer Support Agent
Hi @yoshanaku,
We've responded to your private message. Please check your inbox 🙂
Thank you,
Syed
mimmo
@yoshanaku are you saying that your Koodo sim no longer works? And that the Koodo account is closed?
Can you try calling out on your pm sim? Could you have actulaly ported?  Your Koodo account should only be terminated by a sucsefful port.
mimmo
@yoshanaku you need to message the mods.
How can you get help with your account, activation, or service?
In your message please include:
  • PM Phone Number, 4 digit PIN, Account email address, Detailed explanation of your issue
If you have a Porting issue, please also include:
  • The number you want to port, PM sim number, old account number, old account name exacly as on bill
Don't know your pin?--provide any 3 of the following:
  • Complete mailing address, Email address, Alternate phone number, Date of birth, Last top up date & amount
How long until they reply?:
  • Office Hours: Mon-Fri 9am to 9pm, and Sat-Sun 9am to 7:30pm [Totonto Time] from 9am to 7:30pm [Totonto Time].
  • Messages are replied to during business hours and in the order they are received
  • Typical response time is between 1-3 hours, depending on message queue, but can be up to 48 hours.
  • There is no need to send multiple messages.
Additional Useful Information:
  • Search PM-GUIDE (remove "-" during the search) to find some informative posts and answers to many common questions about Public Mobile
yoshanaku
Can a Mod please reply, going in circles here, confirmed with koodo just now that everything is gone on their end. Still can't get past the check eligibility page on PM.
popping
@yoshanaku
Porting tips:
After initiated porting your number online, continue to use your old SIM card to call out, receiving calls and send/receive text until it is dead.  Then, the number porting is completed and start using the new PM SIM card.
mimmo
Post paid should be pretty straight forward. Try logging into selfserve in incognito mode .  From what I recall it should ask you to enter your number to see if it is valid.  IfIf nothing  is happening  at thaT point then I would wait a little and try again later.  I have had issues with the browser before that's why I suggest incognito mode.
yoshanaku
Coming from koodo postpaid. Auto correct changed it to prepaid by mistake
@yoshanaku, are you getting a specific error message on screen?  I know there are issues if you are porting from Koodo pre-paid to Public Mobile.  In that case you must get help from a moderator.
mimmo
@yoshanaku your title says potpaid but your message says prepaid. My message above was for prepaid
mimmo
For prepaid you need to contact the mods.  First I would sign up with a tempoRy number and use a different email than with Koodo prepaid.  One you have an account message the mods with your Koodo prepaid info.
