Porting from fido problem, no data
11-26-2023 01:37 AM
I just ported two numbers, one from fido another from koodo to PM
Koodo to PM went without a hitch
fido to PM - the phone seems to be experiencing difficulties registering on LTE network - I have no data, and occasionally the LTE logo would come on and then turn off right away
I checked APN, seems to be in order
what else can I check?
Service
11-26-2023 01:50 AM
fixed it.
I have two sims in the phone, and for some reason I had to activate secondary SIM and manually select the SIM that operates for data/calling - android didn't pick it up automatically, even though 2nd SIM was disabled
after I did that, I disabled 2nd SIM again and everything is back online again
11-26-2023 01:40 AM
Restarting your phone as a first step is always good.
Then check to make sure that your actual network type is set to LTE or 5G and not something else.
![](/skins/images/813D49D689E0D681E39391EAB60FD666/responsive_peak/images/icon_anonymous_message.png)
