Porting from Fizz
darkmax1234
Hello, I’m trying to port my phone number from Fizz, followed the account number by adding 0000 at first but the transfer failed
thank you for your help!
@darkmax1234 wrote:
Fizz is still active and PM esim has no number
Fizz has sent their sms transfer which I replied Yes
Then, received a telus sms telling the transfer has failed. So I’m stuck between.
@darkmax1234
Did you receive an email from PM with QR code for eSIM?
Then your account is not likely set up properly and your port also failed.
Send a private message to CSA through the following link :
It may take a few hours for CSA to respond.
darkmax1234
Dunkman
@darkmax1234
Do you have any service wth your PIM SIM card?  If your port is stuck, you should still be able to dial out and sent outgoing texts.  Data also should be working.  Just unable to receive texts or calls on your ported number.
