10-30-2016 09:52 PM - edited 01-04-2022 03:50 PM
I am interested in porting over to Public Mobile.
I have one account with Fido, and 2 lines in that account.
1 line is on a month-to-month plan
1 line is on a contract with couple months left.
I would like to keep both numbers and port both to Public Mobile at the same time.
Are instructions for porting both line the same, and can I port at the same time, or I have to port my primary line, then secondary line?
Thanks
11-02-2016 09:11 PM
@misfiringsystem they will bill you for any outsanding amount once the port completes. You should not need to pre-pay your outstanding device balance before porting.
11-02-2016 09:08 PM
Sorry for bumping this, I have one more question (last one I promise).
Should I pay off my contract with Fido before porting?
Thanks
10-30-2016 10:54 PM
Hi @misfiringsystem, yes many of us on the community recommend doing exactly that--activate with a temporary number and confirm all services working on your phone, and only then do the port from the previous provider.
In your case with the two lines, I would probably personally port the secondary number first, and then the primary. They do have to be done indvidually, as every line at PM is in its own account. I think I would port the secondary first to minimize any confusion at the Fido end. That's just my recommendation, but do what you think is best. 🙂
10-30-2016 10:47 PM
Hi @JaK
Thanks for your response. I have one more question. When my SIM cards arrive, could I activate the
SIM card on a random number first, so I could quickly test out the service and reception, and if I'm please with it, port my number over?
Thanks
10-30-2016 10:01 PM
Hi @misfiringsystem;
Yes you can port both numbers and yes the procedure is the same for both. Technically you should be able to port both at the same time but you might be better off seperately. However if I was to do seperately then I would start with secondary first. Good luck! 🙂
