Porting Numbers
BrendanJ
Hi, I’m wondering if someone is willing to provide me the porting team number as I am having issues porting over some numbers to public mobile. Thanks in advance for your help!
BrendanJ
I accidentally took out the sim card too soon but put it back in. I cannot finish the port because bell hasn’t received the request yet.
BrendanJ
hello, I’m still experiencing issues porting over a number to public mobile. I’ve contacted the porting team but it just forwards me to Koodo mobile.
slusagm
Yes, sent to your community inbox, please check
If any issue, you can also submit ticket to PM
 Since you cannot properly login, you won't be able to open the preferred Chatbot ticket. So, you will need to message them here: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
