03-11-2018 12:23 PM - edited 01-05-2022 04:26 AM
Hi there!
Looking to port my number off of PM to a new carrier. Just wondering what the fastest/easiest way to go about this would be. 🙂
Cheers!
03-11-2018 08:32 PM
@Anonymouswrote:@chillier, Not much to do on the Public Mobile side, except to make sure that your account remains active untill the new carrier takes over the number. And one other important thing, you should remove your CC number from your account (if you have one registered), since you won't be able to access your account once the number is ported out.
Thanks for the reminder about the credit card!
03-11-2018 12:40 PM
