Porting Issue
mohaimen
Hi,
I just ported from Freedom, got an authorization message to which I replied "YES". My Public Mobile SIM is also working, I am able to make calls and use data. Number is fine as well, BUT I got a text just after porting from Public Mobile that there was a "trouble porting the number" due a "incorrect account number". I also didn't receive any email from Public Mobile even though my email is correct.
Should I just ignore the text since I am using my number just fine?
Thank you!
pkaraa
I concur that you should send a msg to CSA to confirm the successful port before you discard that email.
mohaimen
Thank you.
dabr
@mohaimen wrote:
Hi,
Thank you!
@mohaimen   I pm'd you the Telus porting number, but I'm not sure you need it if you're saying your service is working properly.  Perhaps there was a typo in the email being registered, not sure.
Edit:  If everything is working with your phone service inc. number, then you should be able to ignore the message you're getting.  Errant messages do happen around here, unfortunately.
@mohaimen
if you stuck with Transferring your old Phone Number,
Here’s how to contact Customer Support Agent by CS_Agent,
  • or you can send a private message to Customer Support Agent by CS_Agent, by Click Here link.
  • You’ll need to be logged in to your Community account for the link to work.
  • your phone number,
  • which carrier,
Good luck and your welcome to Public Mobile
with a Beautiful Service
you will be very happy....
