Porting In
Londonguy
Got everything setup with a temp number. When I try to port over under transfer number it's asking for a number. What number do I put in. If I put in my PM temp number it says invalid. Am I doing something wrong?
2 REPLIES 2
slusagm
You need to put in the number  currently with another provider, and remember to put  the  other provider account number as well
@Londonguy  You put the number your trying to port over in , but remember you cannot port number from one public mobile account to another public mobile account . It has to be number from another carrier
