09-03-2021 07:51 PM - edited 01-06-2022 03:23 AM
We ported my son's number over from Rogers. It worked successfully for a while. Rogers was notified and the account was removed, my son then had his number for a short while. All of a sudden he was given a new random number. Now we have no idea how to get his old number back and the online tools for 'change number' just say error.
Also can't seem to find any tech support number to help with this issue. Does Public Mobile not have phone support?
09-03-2021 08:40 PM
Did you leave the old Rogers SIM in the phone and reply with YES that you are porting over to PM?
Anyway, contact the PM CSAgent to port your old Rogers number to your son’s account.
09-03-2021 07:59 PM
Make sure that you have the old sim card in your phone when you're porting your phone. You should get a message from your old carrier asking to confirm if you would like to port your number. Your reply should be: YES.
The confirmation message can take a few minutes to come in. You have 90 minutes from the time of request.
i will provide a call number maybe the can help you,
if are you stuck with Transferring your old Phone Number,
Here’s how to contact Customer Support Agent by CS_Agent,
Good luck and your welcome to Public Mobile
with a Beautiful Service
you will be very happy
09-03-2021 07:53 PM - edited 09-03-2021 07:55 PM
Contact a CSA:
All support is online.
Hours of operation:
You will often get an answer within an hour. During peak periods, you may need to wait up to 48 hours.Customer Support Agents are available:
Keep an eye on the envelope icon in the top right hand corner for a reply from the CSA.
