01-25-2026 03:27 PM
Like everyone else, I signed up for the deal and ported my number from Fido. I responded YES to the text asking if I wanted to port, but later got a text from Public Mobile saying I never responded to that request. If I respond with 1 no new text comes through and if I call the number they provided for more assistance, it says there is no porting request for this number. My Fido SIM appears to be working. So does this mean the porting is still on going? It hasn't quite been 5 hours yet...
2 weeks ago
hi @Jagrutishah
you are tagging on an old thread. You should have started a new one
if you are porting in PM, then, yes, PM has to retrigger the port request
have sent you the porting support team number. Please check your Community inbox (https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage), check for the number and call.
And in case the poring team cannot help and ask you to submit ticket (or you rather submit ticket anyway), you can submit ticket by direct message:
2 weeks ago
Telus team is refusing to resend port request. They asked to contact PM
01-25-2026 04:33 PM
It's possible that was the case, although Fido was still active so I don't know why the text wouldn't have worked. This time I started the transfer, called Fido, they confirmed it. I also had already messaged a PM agent, so they responded saying it was done. So it ended up being super fast
01-25-2026 04:07 PM
Ok I just ported over and was having the exact issue you are describing. I realized the issue was that I had both my old Freedom Mobile SIM and my new Public ESIM active at the same time. I had texted YES to freedom yesterday and public said they never recieved. Today I got them to retrigger the request from Freedom and initially I had the same issue where support said they weren't seeing the relese even though I had texted YES. Then I got an idea and just tried turning off my Public ESIM. Then I replied YES making sure I was using tue Freedom SIM only and it worked immediately. Hope this helps!
01-25-2026 03:45 PM
@Wafik2025 wrote:@Dunkman is that the number Public Mobile texted me? Or a different number? I tried calling the number Public Mobile texted me, it said there was no porting request for my number and then transferred me to Koodo?
I sent you the Telus team porting number via private message.
01-25-2026 03:37 PM
01-25-2026 03:36 PM
Did you call the Telus team porting number? Telus team should be able to initiate a new port request.
Fido ports usually are done within 1-2 hours at most.
