Ported phone from Telus to public and not working
Coleen
8 REPLIES 8
@ashleyimasuen wrote:
Hello, Can I receive the porting department number as well, having the same issue porting from Telus to public mobile
I sent to you, check your inbox.
ashleyimasuen
stephenCA
Thank you.
fcf777
Just so you know, I called the porting department and was on hold TWICE for one hour and each time my call was cut off with the message: "We are having trouble connecting your call. Please try or call again later"
@stephenCA sure no problem
stephenCA
Hello @Outdoorsman. Can you PM me the porting department too? I'm having same issues as others and I'll save a ticket by asking here.
Outdoorsman
@Coleen hi there have been many issues with porting mentioned today,I will private message you the porting dept number
will13am
@Coleen , there seems to be a problem with number ports from the sister brands in recent times.  Please use the chatbot link to initiate a support ticket.
