Ported number eSIM activated but no network bars showing can make calls through
RavD
Hi
I ported my number over to Public Mobile earlier today. It seems the number ported over correctly I’m able to make and receive calls and cellular data is working but the network bars on top right hand corner of the phone (iPhone 13 pro) are not there and neither is the Public Mobile network identifier on top left hand corner .
When I go to settings and select cellular, it doesn’t present me within the usual menu options regarding cellular data network , roaming, and all the apps that are enabled for cellular data, statistics etc.
I don’t know if it’s a problem with eSIM or porting. All the iOS options show up correctly when I insert my virgin physical sim but that network is already disconnected
i made a ticket but no one has responded
did any of y’all ever face such a problem & can anyone help please?
rgds
Rav’s
RavD
Sorry for the delay. I’m in another time zone yes I did all that eventually bought two Sims and one physical Sim.. what worked in the end was patience just like the wife was saying and she got an opportunity to say I told you so it’s gonna take time to register think hours maybe even days. If you activation went through without errors, it will eventually register. All the hand wringing , writing here on forums didn’t help what eventually help was forget about it till the time it registers. Somebody from customer care did come back to me after three days. You’ll have to leave a ticket or something for them. That would be beneficial. I know that doesn’t help if you’re short of time or something that should be a warning upfront and big and bold. If you’re short of time, you can’t be out of touch. Do not try to migrate to Public Mobile.
Tipapoute
Did you ever get solution to this, I have exact same problem. I am about to run out to buy a physical SIM
RavD
  • Thank you, Dunkman Yes, I’ve done that too. Couple of times.
RavD
Hi softech
thank you for your prompt response. Appreciate it.
Yes, I had done all those things before I posted but just for good measure I did it again
Here is what I see. No network bars and only the few limited menu options below under settings cellular Much different From your screenshot.
@RavD
best to confirm if porting was successful is to remove  the old carrier sim
if your old carrier has a physical sim card, remove it form your phone
If your old carrier has an esim, please disable the old carrier esim by toggle off "Turn on this line".  Then go back to Public Mobile esim and make sure "Turn on this line" is toggled on for PM esim, and make sure it is now set as Primary.  Then try to make and receive calls again, and check data
Dunkman
@RavD
Remove your Virgin mobile physical SIM card.  Reboot the phone.  If that does not work, you might want to try a Network reset of your phone. Note: this will erase any saved Wifi passwords.
