Port
11-26-2018 02:22 PM - edited 01-05-2022 02:36 AM
11-26-2018 02:53 PM
Try your old SIM. If it works just keep using it until the PM SIM is functional. Do not close your old account; that will happen automatically. Or if you have another phone, use your old SIM in it and carry on with two phones
If your port-in of a cell number has stalled more than 3 hours you will need moderator assistance. If so, send a private message to the moderator team with your PM phone number, 4 digit PIN, and an explanation. Include the following info:
- PM SIM card number
- old carrier account number, exactly as shown on your bill. The DBC part listed in a Freedom account is considered part of Freedom Mobile account number.
- old carrier phone number
- the account holder's name, exactly as shown on your bill
- an Alternate Phone Number; someone else’s, not your own
11-26-2018 02:49 PM
Sounds like you have a stuck port.For this i believe you must send a message to the moderators.If there are other options im sure someone will post them
