08-06-2017 09:03 PM - edited 01-05-2022 02:35 AM
Hi,
Can a mod please check my credit card which is attached to my account. It seems that a change which was made 2+ months ago was not reflected for autopay. My previous card was charged, not the one which I have setup through self serve.
I just went to manage card and re-entered the correct card I want to be using. I need this verified as I am closing my AMEX account (previous card).
Thanks,
Kevin
08-06-2017 09:32 PM
@nivek Try logging into your account and delete the current card; be sure to save changes. Then go back to Add Credit Card and re-enter the one you want to use.
08-06-2017 09:30 PM
08-06-2017 09:05 PM
@nivek wrote:Hi,
Thanks,
Kevin
@I think you simply need to tag @CS_Agent .. they'll sort out the rest.
