Port number help
Bozena14
Submitting a ticket doesn't work, need to Port number from Rogers thanks
2 REPLIES 2
Andy85
Hi @Bozena14,
What issue are you experiencing? Maybe we can pinpoint the step that should be taken and help you further.
In case you need the porting team's phone number, I'll send it to you via private message. Check your community inbox (envelope icon if you're in a desktop) for the message. Let us know if you have any additional questions!
@Bozena14  I will send you the porting team number private message and they can re trigger the port request for you . But here’s the link for support should you need them at all
send a  private message   To CS_Agents
