Port my phone number
Pritam
Please port my phone number from koodo mobile
Murse20
If you're porting from Koodo you need to first activate a Public mobile account with a new number. Then port your number from Koodo it will automatically switch when you request it as mentioned above. Takes a few hours but it does switch eventually and work well.
Hi @Pritam
Porting from Koodo:
If your switching from Koodo postpaid(monthly) your can port-in your number during sim activation. Just have your Koodo account number, name on the Koodo account and Koodo number ready and enter it when choosing your number.
If it's Koodo prepaid then you need to click link and type in “port request” to be put in touch with a Moderator. Include the Koodo info above.
shep22
@Pritam contact the moderators ask Simon the robot  here to speak to a human this will help to generate a ticket mention  port request  check envelope top right for a response they usually reply between 2-48 hours
