Port issue!!! Urgent !
gh722
My number was ported over a couple days ago but not released properly on my old provider.
I cannot receive incoming calls right now , and I now have the proper old account number , could someone please help me set up the port so I can be fully on Public Mobile ?
thanks!
Jarvar
Welcome @gh722 to Public Mobile.
Sounds like there was a speed bump with your Public Mobile account setup.
 If there was some incorrect information, or even if the port was not submitted properly. Like @Anonymous mentioned, contacting the Moderator Team will set you straight.
I had a similar issue when I signed up with Public Mobile. I could call out, recieve text. Even had data working, but when there was any incoming calls, it would go straight to voice mail of my previous provider.
I hope this gets fixed for you soon. Sometimes the wait can be a bit long to hear back from the Moderators, but atleast you are queueing up to get the issue dealt with.
6500K
thanks!
Would you elaborate what you mean by "not released properly on my old provider"?  Also does "I now have the proper old account number" mean that you can see your telephone number in your settings on your phone?
thanks!
You'll need to contact the mods here as you say your porting info was incorrect.
Send ONE (1) private message to them here and include your phone number and PIN to minimize back and forth identity verification delays.
Forget your PIN? Then you'll need 3 of either of these pieces of information you used when you signed up: full address, birthdate, last 4 digits of CC you might have used, email address on the account, alternative phone number you might've entered when you signed up. Or, in addition, either of these to get to 3: last payment amount and date, last add-on bought and date.
And of course your question/problem.
Then hopefully they will get back to you as soon as they can between M-F 9-9 (ET) and Sat-Sun 9-7:30 (ET). But it could be up to a couple days.
Depending on your notification settings, you would get an email notifying you of a reply. Get back here and see a red blob over the little envelope in the upper right of your screen and click on it to see the message.
