Port in number to public mobile
Wjp
How do you port in a number after activation from a different carrier
JL9
This is important @Wjp also make sure your old account is in good standing, these 2 things are need to successfully complete the port.
@Wjp
After activating your SIM, remember to keep your old SIM in your phone for a text confirming you are porting over to PM.?Reply to the text with YES within the 90 minute window.
@Wjp  you can check to see if your number can be ported from this Koodo website (Telus owns Koodo and Public Mobile), so, same allowances here:
https://secure.koodomobile.com/checktransfereligibilityparrot/default.do?lang=en&appname=otherportal
See more info. about transferring your number in the Public Mobile's get help articles here:
https://www.publicmobile.ca/en/bc/get-help/articles/port-fraud-protection
@Wjp   No worry, you can request porting in after you activated.  Just login to My Account and click Change Phone number ,select "Transfer a wireless or.."
Follow the steps after.  it is better to enter the account number of your old provider instead of your IMEI
https://selfserve.publicmobile.ca/Overview/ChangeNumber/https://selfserve.publicmobile.ca/Overview/ChangeNumber/
