a week ago
Only data and outgoing calls works
Issues:
no outgoing test
No incoming text
No incoming calls
a week ago
Thank you. The number helped resolve the issue.
Port complete
a week ago
I also had issue with porting from Fizz. Can I get the porting team number please?
a week ago
Can I get the number of the porting team?
a week ago
@Hengmin Sent you the number
a week ago
Same issue here.
a week ago
your port was not done
there is a porting assistance team you can call and ask for update. I can't post the number here, but I will message the number to your community inbox. Please check and call them
But if you cannot reach them or they said they cannot help, you will need to contact PM using this link
And CS_Agent will reply to your community inbox, check here:
https://productioncommunity.publicmobile.ca/t5/notes/privatenote
a week ago
@nimeshm Sent u the number too
a week ago
Same issue here
a week ago
@Jon14 Sent !
a week ago
If there is a number, I'll definitely take it too 🙂
a week ago
@batoolxhasan Sent !
a week ago
Can you send it to me too, thanks
a week ago
There is no number with Public Mobile, it's an online only service 😕
a week ago
@Tonisage-1 Yes sending you it private message as we can’t post it here
a week ago
Can I get the number to the porting team? My port is incomplete
