Port confirmation text
Courtneyh01
Stuck at step 6, seems like a lot of people have this issue. I won’t reload or let me go back to try again and re send sms to transfer number. I wasn’t able to receive the text. I just need it resent. Help please!
@Courtneyh01
the team I sent you should be able to re-trigger the process as long as the port request is not over a month.  You can try calling again
But at the same time, message PM support , they can for sure help , just take a bit longer
Courtneyh01
They weren’t able to help because the 90 minutes were past. They had no idea about anything
Courtneyh01
I took out my old sims before confirming the text, I still have my old plan active. So I can make calls. Physical SIM. I will attempt to call
@Courtneyh01  physical sim or esim?
can you at least able to  make outgoing calls?
For port, there is a number to call to talk to live support to get the port status,   they can re-trigger the process for you.  I will message the number to you via the Community inbox ( https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage ) .  Check the envelope icon on top right.  Call them and get it fixed
