Port a number
Justinwaltersbi
I activated a new phone with virgin mobile and I want my number I've been using with public but won't allow me to port it over why not?
I made my line very carefully
PM doesn't stop the number from porting out, just Bell cannot accept the number because they don't have service there, the issue is in Bell side and not a restriction on PM side
@slusagm wrote:
Is your PM account still active? If it is but it cannot be ported to Virgin Mobile, then it is a question with Virgin.  PM allows any number from an active account to port out with no restriction
That can't be stated as an absolute certainty.  While this isn't usually the case, there are times when an active Public Mobile cannot be ported to Virgin Mobile.  This would occur if Virgin Mobile (Bell) doesn't offer its own for numbers for that same city.
slusagm
Justinwaltersbi
My pm account is still active
hi @Justinwaltersbi you have to make sure your PM account is still active before you can porting out to any carrier
