Hello,
I wanted to port the number on my current accoutn out to another provider and bring a number from that same provider over to us, so its basically a number swap. Is it possible to keep my current PM account and sim card or will I loose everything?
For the other provider I need to have a second sim card to port my PM number to. Once they take my number from PM, can I then still pull in the number from them to my PM or will my account and sim be deactivated after the port?
I need to find a solution that will allow a 2 way swap, any help is appreciated.
