11-14-2018 02:00 PM - edited 01-05-2022 06:07 AM
I've been with Public Mobile for almost 3 years and I've had no issues until about a month ago. When at home my reception drops considerably. When in the basement I will have 1 bar or no connection. When in the kitchen above ground I will have anywhere from 1-3 bars and will not receive calls or when speaking to someone they can't hear me. I have no idea why and it's starting to get frustrating. The only thing that has changed was that I switched from one PM plan to another in August. I have the Samsung Note4 and no other unlocked phone to test the sim card in (I've been reading some posts). I'm desperate to find a resolution.
11-16-2018 07:25 AM - edited 11-16-2018 07:51 PM
It's interesting
11-15-2018 11:46 AM
So you just replaced the old sim card with a new one... and everything was fine.... Did you have to do anything else?
11-15-2018 11:44 AM
So far it seems like its just when I'm at home. I have full bars once outside my house. I ended up doing a factor reset (not necessairly for this issue) and it didn't seem to make any difference with my reception. Possibly changing the sim card can fix this issue?
11-14-2018 02:24 PM - edited 11-14-2018 02:53 PM
Keep walking around your neighbourhood to confirm it's a very specific locale. If it is more general perhaps the phone is failing.
Anyway, changing plans would have no affect on reception.
11-14-2018 02:22 PM
i have the same issues befoer when i did exchange Sim Card, is fix it
you have to try exchange your Sim Card.
Good Luck
11-14-2018 02:13 PM
I'm assuming your suggesting I go into "Mobile Networks" and change the Network Mode. I've switched them back and forth and neither works well. LTE/WCDMA/GSM (auto connection) and/or WCDMA/GSM (auto connect)
11-14-2018 02:04 PM
Try setting the phone to 3G instead of LTE/Auto. Works better where I live.
