Points
Hockeymom77
I used points on my kids phone numbers through their accounts and I was required to pay additional to get their lines up and running. I used my points on my line and I didn't have to pay. So I'm wondering if this is a error. If needing the numbers to check I can provide their numbers.
Thanks
Lorraine
9 REPLIES 9
hi @Hockeymom77
so the credit card shows your kids were charged $40+?
according to the payment history of all 3 lines, there were only charged $20 after the $20 credit
I guess you can ask PM support agent o check and confirm
submit a ticket with CS Agent using Chatbot here:
             Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
             (If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit  ticket by direct message:
Hockeymom77
Thank you, they are deleted
Hockeymom77
Why did it charge my kids to pay and not mine. That's what I don't understand.
Thanks
Lorraine
hi @Hockeymom77
so, everything is good as it should be then
and btw, someone helped to removed your post with the screenshots.  But you still have to delete it off your profile
go to here
https://productioncommunity.publicmobile.ca/t5/media/gallerypage/user-id/526499/tab/all
click X on the top right of each pic to delete
Hockeymom77
No it didn't charge me 39.95 plus tax. I paid 20.95 as the 20$ credit (in points was taken off yesterday). I went to look at mine and i did the same thing and I didn't have to pay my amount. My account says we we take payment on March 21.
hi @Hockeymom77
we don't need the phone number.  click the down arrow on the top right of your post and Edit Message to remove them
and you sure the bank charged you $39.95+1 ? for all 3 accounts?
hi @Hockeymom77
is the difference around $10+ tax?  if it is , then it will be a referral credit of $10
or go to Payment history on both accounts, take screenshots and post here and we can help.  of course, remember to hide the personal info
Hockeymom77
We all have the same plan at 40.95. so I don't understand why I had to pay difference on theirs and not mine
hairbag1
@Hockeymom77
if you redeemed 20 Points, that was will be added to your Available Funds to pay for $20 of next regular plan renewal cost. If the plan costs are higher, you'll pay the diff on your on-file payment card. If the regular plan cost is $20 or less...you'll have enuff to cover it with the redemption.
