08-15-2020 02:19 AM - edited 01-05-2022 12:32 PM
08-15-2020 03:57 AM
There is no build your plan per se but you can exercise a certain amount of control over the $15 plan if you are a low user of services. The plan comes with unlimited texting and incoming calling and 100 minutes of outgoing calling. Additionally it has 250mb of data(w/autopay but you get it regardless.....) each month. More than enough for most people but if your usage varies you can add the following add ons to your plan and they remain on your account til they are completely used up:
If you need a little more than your plan includes then purchase and use as needed. For most users a couple of add ons for additional back up usage on average adds $1 - $3 per month.
08-15-2020 03:00 AM
There is no build your own plan in Public Mobile.
08-15-2020 02:20 AM
@Bunzyman204 hi sorry the only available plans for pm are the current ones they are offering
