Plans
Jadyn30
If I purchase the 20gB plan for 34/month, will that be my plan going on in the future or will that only be for a limited amount of time
@Jadyn30
The plan and price will stay with you as long as you are with PM. Black Friday is just around the corner so there might be a better deal coming up but who knows.
SourDude1234
If you are a new customer, after purchasing, be sure to switch your plan to the 34$ one for 5G since that is an option now but you have to be an existing customer! Switch it by logging in to my account, click on "change subscription" and then select the 34$ 5G plan.
HALIMACS
@Jadyn30
while Public Mobile has the legal right to amend or remove a plan offering, they are required to give a certain amount of notice before doing that.
It has happened – however I don’t see them applying that to the $34, 20 GB plan given it’s a medium to higher data plan.
I, myself, have two people within my group who are switching to that plan on their next renewal.  They will likely be on it for as long as it’s available, or until something more attractive comes along.
hairbag1
@Jadyn30
it'll be yours until you change it to something else. As long as your plan stays Active and in good standing.
