Plans ending
KZ1964
Not sure if this is the correct place to post.  But for those who are unaware alot of the PM plans are dated to end today
$15 talk and text (Ends July 25)
$20/2GB 4G (Ends July 25)
$23/6GB 4G (new activations only)
$29/30GB 4G (Ends July 25)
$34/50GB 5G (Limited Time)
$34/50GB 5G Canada-US (Ends July 25)
$40/75GB 5G Canada-US (Ends July 25)
$50/100GB 5G Canada-US (Ends July 25)
The $15 talk and text plan ends on July 25 too, along with the $20/2GB plan and $29/30GB plan.
2 REPLIES 2
szu
That is when Public mobile will likely change plans.  Some plans will remain the same, while new plans may also be offered.
Sansan
Yes, thanks for advising.  That's what they have indicated.  I wouldn't be surprised however if they are still here next week.
Public Mobile is known to change the information they put out there either before or after time-frame indicated.
Can be either good or bad, depending upon ones needs.
I'm curious, however, to see what 'new' offers they will provide.
