03-17-2021 01:55 PM - edited 01-05-2022 05:37 PM
I purchase a $15 plan on Feb 26 and use up my 100 minutes then deposit $15 into my account so I have a $15 credit on my account. My phone is not working because I used up the 100 minutes so how do I get the phone to work.
03-17-2021 04:28 PM
@ghamblen wrote:I purchase a $15 plan on Feb 26 and use up my 100 minutes then deposit $15 into my account so I have a $15 credit on my account. My phone is not working because I used up the 100 minutes so how do I get the phone to work.
Were you able to purchase the $5 addon?
See how here:
https://www.publicmobile.ca/en/bc/get-help/articles/purchase-add-ons-using-your-self-serve-account
It is a great buy, and likely more worth it to get this than renewing your plan early.
NOTE: Purchasing an Add-On?
Be sure to:
1. Add funds to your account, if you don`t have sufficient funds
2. Go back to the Add-Ons page and select your Add-On.
3. Reboot your phone.
03-17-2021 02:04 PM
Hi @ghamblen if you ran out of minutes, you can purchase 500 Canada-wide minutes for $5.
RosieR
03-17-2021 01:58 PM - edited 03-17-2021 01:59 PM
This is not a pay as you go place. Adding money doesn't do anything until renewal. Or you can use that money now and buy the $5 calling add-on. Then when your plan renews the end of this month you'll return to using your plan minutes and the add-on will step back waiting to be needed again. Then your autopay will only need $5 at that time.
Edit: slow
03-17-2021 01:57 PM
Adding money to an account does not automatically provide you with more minutes as there are no pay-per-use charges at Public Mobiel. To get calling services to work again, you'll have to either purchase a $5 for 500 minute add-on (or you could ask for an early plan renewal, but the 500 minute add-on is less expensive).
