Plan
broz
Hi, not able to change from $ 25 plan to $19 plan with better speed.
2 REPLIES 2
Rastin
Pm has made it almost impossible to downgrade your plan. If you want something cheeper your choices are port your number out to another provider and port back to pm to get the deal you want or just find a different provider with the plan you want and just port to them and stay there.
slusagm
Sorry , you can't
You can only change to plans available on your Change Subscription page.  And $19 plan is never an option for people with a $25 plan.  Sorry!
