Plan
KACHASAFA
What happens if I exceed my data limit, will I be charged or can use at a slower speed?
2 REPLIES 2
Chalupa_Batman
Hey @KACHASAFA
Unless you're on a 5G plan, your data will run out when the allotted amount is spent. If you're on 5G you will have unlimited after the allotted amount at 512kbps
@KACHASAFA PM is prepaid service so no extra charge unless you opt for add-ons
Only if you have 5G plan and you will have unlimited low speed data at 512Mbps after using up your regular data
For non 5G plans, the data will stop working unless you buy extra data add-on or wait till the start of next cycle
