09-18-2022 12:44 PM
My plan renewed yesterday and my cellular data is not working ? Can’t get ahold of anyone to find out why ?
09-18-2022 11:31 PM
@quarrington A scheduled plan change screwed up the renewal. That was a problem since Friday. PM Support can certainly have the issue fixed, just hope they get to your ticket soon
I would wait till tomorrow morning and message them again for an update.
09-18-2022 10:24 PM - edited 09-18-2022 10:26 PM
@quarrington- Yes that's a ridiculously stupid bug that has affected people for a couple days. You'll need to wait for a response.
Adding - edited.
09-18-2022 10:22 PM
@dust2dust yes just switched it from 3G to 4G
09-18-2022 10:06 PM
@quarrington- Did you change your plan?
09-18-2022 09:37 PM
I am having the same issue, I've submitted a ticket but no resolution yet... would love to hear if there is a fix possible on our end
09-18-2022 09:10 PM
09-18-2022 05:04 PM
Same here. Service renewed yesturday and shows active but in fact have NO SERVICE on my phone with incoming calls or texts and zero data
09-18-2022 01:22 PM
Thank you very much 😊
09-18-2022 12:57 PM
While it is not encouraged to bypass the ticketing system, if you are struggling with initiating one, you can private message the CSA team directly using this link. You will not get a ticket number and response time might be longer than using the ticketing system.
09-18-2022 12:52 PM
Hi yes I did change the plan yesterday ! Having hard time to send in a help desk ticket
09-18-2022 12:48 PM
@HS3 , by chance did you do a plan change as part of renewal? The renewal bug has reared its ugly head in recent days. Are you able to confirm that your self serve account is in active status and restoring it to active status if suspended. If assistance is required, use the chatbot link at the bottom of the webpage to initiate a support ticket.
