Plan odds
rukemeric
I purchased plan odds for calling international it’s not working
RossN
@rukemeric hi on top off all the good advice mentioned above, check in your plans and add on section to see if is is showing there
HALIMACS
Hi @rukemeric
Also, make sure you're calling a location INCLUDED with the add-on you purchased.
Not all international locations are included with all international related calling options.
Are the funds in your available balance? For purchasing add-ons, the funds must be already in your Public Mobile account. If they are not, the purchase steps only apply a top up. You would then need to go back and peform the procedure again.
Gunner123
@rukemeric  hi there are 2 steps first put money in account and then go back and purchase add on
ShawnC13
@rukemeric, purchasing add-ons is a two-step process.  The first purchase puts the funds into your Available Funds account, you are then required to re-purchase the add-on to have it activated to your account.  Did you complete the two-step process?
* I am happy to help, but I am not a Customer Support Agent please do not include any personal info in a message to me. Click HERE to create a trouble ticket through SIMon the Chatbot *
