12-15-2020 05:36 PM - last edited on 06-05-2022 07:02 AM by computergeek541
I receive an error message when I try to forget password. Any help would be appreciated?
12-15-2020 05:41 PM
The fastest way if the other options don't work is to talk to a mod using the link below:
12-15-2020 05:39 PM
@Wejamjam1 wrote:I receive an error message when I try to forget password. Any help would be appreciated?
Why would you want to forget your password? 🙂 Couldn't resist.
Try a different browser or clear cache/site cookies or use incognito/private mode and then try the Forgot your password? link again.
12-15-2020 05:37 PM
hi if you can't remember your password or it is not working contact a moderator you can do so by clicking the chat bubble at the lower right corner,to avoid going around in circles with Simon say that you want a human to speak to, a ticket will then be generated briefly mention your issue password reset
you should get a response between 2 to 48 hours a reply should show up in your little envelope in the top right corner, you can also send a private message to the Moderators by clicking here.
