01-25-2018 11:21 PM - edited 01-04-2022 03:24 PM
Both my parents use either Telus or Fido and they top up their accounts with $10 every month just so that their minutes do not expire. I believe that its $0.15/min at Telus, so ~70 mins. They hardly ever call so their accounts are at $100+ since they have to top up to prevent the money from disappearing.
My questions are:
- Will they be able to get a 90 day plan with no talk, no data and no text ($25 / 90 days - $6 for auto pay) but add a 400 minute add on ($15) once or twice a year?
- If I referred them, would that count as a referral? (i.e. $2/month off)
- If they get a text, and they don't have a plan with text, would they still receive it?
Thanks in advance!
Joining Public
01-26-2018 09:03 AM
@Nebula, unfortunately this prepaid service doesn't offer by the minute plans and so it is likely not the most cost effective solution for a user profile that involves using minutes sparingly. I would suggest shopping for a prepaid service that charges by the minute with the longest expiry. Since this not a shopping forum, discussions of this nature is frowned upon. If you like, we can take the discussion offline via private message and I can give you some advice based on what I know of the marketplace.
01-26-2018 12:16 AM
@Nebula wrote:Both my parents use either Telus or Fido and they top up their accounts with $10 every month just so that their minutes do not expire. I believe that its $0.15/min at Telus, so ~70 mins. They hardly ever call so their accounts are at $100+ since they have to top up to prevent the money from disappearing.
My questions are:
Thanks in advance!
As @NDesai mentioned your parents would need to choose at least one option (talk, text or data) to create a valid plan.
They would need at least the talk option if they want to add a talk add-on. To receive a text they need the text option in their plan.
If you are on a rewards eligible plan (legacy plans, activated before January 2015, are not eligible for rewards) you can earn $2/30days for referrals. Your number needs to be added at the time of sign-up.
(If your parents are only using their cell phone for emergencies there are economically better options out there. SpeakOuts minimum top-up is $25 and lasts 365 days, for example (relatively high pay per use prices, though...))
01-25-2018 11:27 PM
@Nebula Selecting no Talk, Text or Data would not be a valid plan. So no, you cannot have a plan without anything.
