08-09-2025
09:22 PM
08-09-2025
10:12 PM
computergeek541
Hi
I lost my phone and had to get a new sim as replacement. Changed the sim on my account to this new one and now my plan cycle is reset even though I still have about 2 weeks left.
Would really love some assistance with this.
Thanks!
08-09-2025 10:13 PM
They didn't charge me yet for a new cycle. My plan cycle just expired after the switch even though with two weeks left in it.
Thanks a lot for the answer!
08-09-2025 09:57 PM
That should not have happened
Did you check Payment history page to confirm if PM really took money again?
If it did, you will have to check with PM by open ticket
Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
08-09-2025
09:28 PM
08-09-2025
10:13 PM
computergeek541
@Geensticks wrote:Hi
Thanks!
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
