12-21-2019 09:40 AM - edited 01-05-2022 08:38 AM
I was pretty sure I switched my plan to the limited special for the USA canda data roaming plan back in October and it never switched over
who would I contact to see what happened??
12-22-2019 05:14 PM
That's possible hopefully it comes back and I get it right thanks
12-21-2019 09:58 AM
@Hawkeyerffr there typically is a confirmation pop up window asking are you sure you want to proceed with plan change, maybe you didn't go through the full process.
12-21-2019 09:50 AM
I thought I ticked to start the next billing date it doesn't really matter next time it's offered I'll get on top of it right away
12-21-2019 09:45 AM
When you say pretty sure what do you mean? Did you future date the plan change or do an immediate plan change?
I don't recall hearing of any failed future dated plan change failure reports since 2016, so I think you would be hard pressed to get a mod to retroactively provide the the plan. Unless you had some proof of the request like a screenshot or something.
12-21-2019 09:44 AM
@Hawkeyerffr wrote:I was pretty sure I switched my plan to the limited special for the USA canda data roaming plan back in October and it never switched over
When in October did you try to change it?
That plan was dropped on Oct 11. If you had set your plan to change BEFORE the 11th for your next renewal then it should have changed.
But really...you're just noticing now?
