11-15-2022 10:19 PM
Hi. My plan has changed from 55$ for 20g to 70$ for 18g. I did not authorize this. How do I get it change back? Thanks
11-15-2022 10:47 PM
Thank you.
11-15-2022 10:45 PM - edited 11-15-2022 10:52 PM
@Bsimons if you did not make any plan change, probably it is a glitch on the system, please open ticket with PM Support and have them to investigate:
1. If you have access to My account: At https://publicmobile.ca/chatbot.
2. If you don't have access to My Account or have trouble with Chatbot: Private message CS Agent at:
11-15-2022 10:44 PM
I did have that before I changed to my current plan of 20g. Months ago.
11-15-2022 10:41 PM
11-15-2022 10:40 PM
11-15-2022 10:38 PM
Does this explain?
11-15-2022 10:36 PM
11-15-2022 10:21 PM
@Bsimons $70 for 18Gb? there is no such plan on the current Plan lineup
is that a scheduled plan change? or you already changed to that one? can you login with Incognito Mode and make a screenshot and post us the $70 plan details?
11-15-2022 10:21 PM
@Bsimons , please check your self serve account again using incognito mode on the browser. You might be seeing an old cached web page. Note that there is a $40/15GB plan option that might work for you at a much reduced cost.
