11-09-2020 03:33 PM - edited 01-05-2022 04:04 PM
11-09-2020 05:39 PM
Working now, thanks!
11-09-2020 05:30 PM - edited 11-09-2020 05:32 PM
@fivecinco05 wrote:When logged into my account, I click on the Plan & AddOns tab, which takes me to an error page. Hopefully this is being worked on, if not I just wanted to bring attention to the issue.
This things happen every once in a while. Usually, if you try loading your account page at a later time, things usually will have been resolved with you needing to do anything. I'm not sure that the incognito mode method would work, but it's worth a try. From what i've found, the incognito mode method is is usually best for when the self serve website loads a completely blank website, but even then , this "trick" seems to only be a temporary work-around for some web browsers to a general website issue.
11-09-2020 03:35 PM
@fivecinco05 It works fine on my account. Did you log out and try again?
11-09-2020 03:35 PM
Try waiting an hour and try again.
11-09-2020 03:34 PM - edited 11-09-2020 03:35 PM
Clear your browser cache/history/cookies. Close browser and open a new browser in incognito/private mode. You can try a different browser.
